Loweredon33s
Why can’t you believe that it could be manipulated by custom tuning just like the other stuff? Is the variable voltage system so sacred that it can’t be altered? We do it all the time man.Like said unless they disabled the variable voltage system then it's not running that high of a voltage all the time. There's an easy way for you to check and I can promise you most likely your custom tune did not disable it
