fortywater12
- First Name
- Evan
- Joined
- May 17, 2021
- Threads
- 16
- Messages
- 249
- Reaction score
- 441
- Location
- Sacramento, CA
- Vehicle(s)
- 2019 Ranger XLT FX4
- Occupation
- Engineer
- Thread starter
- #1
Figured I would make thread documenting my wedge camper build. I have decided to make a wedge camper very similar to the GFC design. I am, for the most part, copying the infamous "Ripcord Camper" build that many on the Tacomaworld Forums use. The space frame needed to be modified to fit our ranger bed, and I increased the overall width of the wedge portion to 52" wide to properly fit an Exped DUO LW mattress. The thread for his original build can be seen here:
How to: DIY Wedge Camper
The wedge portion will be constructed out of 80/20 aluminum and the space frame will be 16 gauge steel tubing. I will use MaxMetal panels (known as dibond to some) for the roof, sleeping platform, and sides of the space frame.
The original BOM for his build can be seen for free in the above thread. My parts list specific for this build (BOM) can be seen here with updated pricing:
FortyWater12 Ranger BOM
I started with the modification to the space frame in Solidworks. The main changes were accommodating the different bedrail width, different bed length, and removing the taper of the frame where it meets the front of the cab. This will be fully sealed, riveted, and covered by the wedge, so I am not worried about any water intrusion. I figured the 0 deg taper at the front would fit our trucks better and provide a cleaner look. I constructed the frame entirely out of 1.5" square steel tubing that is 0.065" wall (16 gauge), aside from where the frame meets the bedrails, which it is 2" x 1" 16 gauge tubing. The most difficult thing about building this frame will be the compound angles for the side 45 deg supports, as well as the rear vertical supports. Note that they are angled in 2 directions.
I was able to order my 80/20 extrusion from TECO Industrial in the Bay Area, California. The price wasn't bad for the extrusion, but freight kills. It was about $300 extra in shipping charges/freight. I decided to go with a 100" x 52" top wedge portion. This will allow for a 52" x 78" Exped to sit snugly in the frame. The lower portion of the pop top will be 4.5" x 1.5" 15 series extrusion and the top portion will be 1.5" by 1.5" 15 series extrusion.
I will be ordering my steel today through a friend at a local 4WD shop here in Sacramento, CA, then will start the fab of the space frame while my 80/20 is anodized and shipped to me.
For the panels, I went with 3mm and 6mm MaxMetal.
I will update this thread as I continue the build and work through issues etc!
- 5' x 10' white 3mm sheet for the roof
- 5' x 10' white 6mm sheet for the floor (what I will sleep on)
- (2) 4' x 8' black 3mm sheets for the sides of the space frame
