PltFX4
Brian, fair enough, easy is a little to kind of statement on the rears... do-able for sure, but you will work for it.I installed the Eibach rears and maybe they are longer than the 5100’s.
My suspension was fully unsprung with the rear tire an inch off the ground and the Eibach was still about 2 inches to long so I had to use a small floor Jack to push it up so the bottom bolt would go in.
Not sure if my setup is much different than others who have suggested it was easy and would just slid in. Certainly doable if you have 2 jacks.
Brian
