RunNwld
- Thread starter
- #1
TO: All U.S. Ford and Lincoln Dealers SUBJECT: NEW VEHICLE DEMONSTRATION / DELIVERY HOLD - Safety Recall 19S43 Certain 2019 Model Year Ranger Vehicles Rear Tail Lamps AFFECTED VEHICLES Vehicle Model Year Assembly Plant Build Dates Ranger 2019 Michigan June 4, 2018 through August 16, 2019 Affected vehicles are identified in OASIS and FSA VIN Lists. REASON FOR THIS SAFETY RECALL In some of the affected vehicles, terminals in connector C422 may be misaligned and may have been damaged during assembly. If a misalignment occurs and terminals are pushed out, there may be a loss of functionality of both the left and right rear tail lamps. While the center high-mounted stop lamp (CHMSL) will continue to function ensuring some level of stop lamp indication, all rear tail lamp features will not function. This includes the stop, turn, rear position, and reverse lamp features. This condition may be intermittent. The C422 connector is a 34-pin inline connector and is located on the 14290 to 14405 harness mounted to the left frame rail around mid-vehicle. SERVICE ACTION Before demonstrating or delivering any new in-stock vehicles involved in this recall, dealers are to inspect connector C422, checking for any terminal push out, and if necessary replace the hard-shell connector. Simultaneously, a continuity check will be performed on the ground circuit, from the tail light to connector C422. This service must be performed on all affected vehicles at no charge to the vehicle owner. OWNER NOTIFICATION MAILING SCHEDULE Owner letters are expected to be mailed the week of January 6, 2020. Dealers should repair any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter. PLEASE NOTE: Federal law requires dealers to complete this recall service before a new vehicle is delivered to the buyer or lessee. Violation of this requirement by a dealer could result in a civil penalty of up to $21,000 per vehicle. Correct all vehicles in your new vehicle inventory before delivery.
