Strange 'chirping' noise 2020 XLT 4x4
bk3528
San Diego
2020 Ford Ranger XLT 4x4
I've been hearing this weird chirping noise inside the cab sporadically for the last couple weeks.
The noise comes and goes and usually only lasts about 2-3 minutes each time. It seems to be happening at speeds between 35-70 MPH. Once below 30 MPH, it stops.
While the noise is audible from inside the cab, the cab doesn't seem to be the source of the noise.
Have any of you had a similar issue? Video attached with sound for reference.
Additional Details
2020 Ranger XLT 4x4
~5,000 Miles
Going to schedule maintenance at the dealer but wanted to get a gauge here first. Thanks all!
Ranger2021
KY
21 Tremor.
I get a chirping noise when I start the truck cold then it goes away. I was thinking it was a belt.
Samsquanch
Maryland
2017 Expedition XLT
It’s the waste gate actuator. It’s a known “problem” with these trucks. Not sure if it actually caused a problem though can’t find anything that says it does.
bk3528
San Diego
I'm assuming this is in response to Ranger2021's cold start post, rather than than my original post? Or are you thinking it's the same issue?
Samsquanch
Maryland
2017 Expedition XLT
Yep I was referring to the cold start up. Although yours could be the same. Do you get the chirp when the truck starts?
bk3528
San Diego
Gotcha, no never when starting or idling. Only when traveling 30+MPH. And it's rather in-frequent. Maybe once/twice a day for 2-3 minutes on 30 minute (60 min total) commute.
CO2Ranger
Look under the hood. Check for critters.
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
bk3528
San Diego
Here ya go, Maybe this is the same thing. I remembered this thread, but had to Google to find it. The search functions on forums like this aren't the greatest.
https://www.ranger5g.com/forum/threads/chirp-sound-coming-from-the-engine.2909/
Thanks for forwarding. I came across this thread on a google search, but it doesn't seem to be the same noise as mine - unless I'm missing something. It also looks to be at idle as well, which is not the case with my noise.
The only similar thread I've seen online (with actual noise clips attached) is this one from an Explorer forum - yet the diagnosis was not confirmed within the thread that i can tell.
wanted33
Down south in Dixie
Old used up LEO
I was hoping this one could help you. My knowledge of turbo engines would fit on a pin head. This is the first one I've ever owned. I got left behind when manufacturers started covering their engines with a big old slab of plastic. Good luck, I know how little things like this can be so aggravating. Post back if you find the cure. It could help someone else along the way.
MeatCutter
Richard
East Coast Florida
2020 Ford Ranger XLT Sport
Meat Cutter
Hi bk3528. My 2020 Ford Ranger just started making the same noise. Only while in gear and at speeds from 35 - 70. Seems to only happen after the vehicle has been parked for more that 24 hours, i.e. the more I drive it the less I hear it. Did you ever find out what is causing this. I've read it could be the center driveshaft bearing.
wmadoty
Alan
West Frankfort, Illinois
2020 Ranger XLT Crew Cab 4x4
Technology Manager
Rule out a restriction in the cabin air filter. When you hear the noise turn the AC off and see what happens. I have a chirp that goes away when I turn off the AC. Pretty sure I need to replace the Cabin Filter. Good luck to you!
