Tom_C
- First Name
- Tom
- Joined
- Apr 17, 2021
- Threads
- 25
- Messages
- 1,629
- Reaction score
- 3,322
- Location
- Virginia, USA
- Vehicle(s)
- 2020 Ranger Lariat SuperCab FX4
- Occupation
- System Admin
- Thread starter
- #1
I have a thread to collect information, but since I can't edit the topic name I will make a new thread in DIY. Original thread https://www.ranger5g.com/forum/threads/3rd-brake-light-wire-location-in-bcm-under-dash.13217/
I have LED lights so couldn't just add a strobing LED bulb. I used this module, and there are others available. http://www.3rdbrakeflasher.com/brak...1.html?zenid=3375bb80e2a9a1dd9c8d510dba623ed1
It took all of about 10 minutes to install, once I figured out the wiring. See the original thread for info. The 3rd brake light uses the yellow/gray wire in the top left connector on the BCM. There appears to be 2 yellow/gray wires, or maybe I can't see the other color correctly, but the wire you need goes to pin 13, so run it back to be sure.
I used bullet connects so if the module dies I can put it back to stock easily. There are 3 different flash speeds you select by connecting certain wires on the module. I used the medium speed. It flashes 4 times in 1 second and then stays on constantly.
I'll try to get a video, but you get the idea.
