JB Weld stick epoxyHow would you attached metal screen material? Others have used HVAC ducting tape, which I am not sure will stand up to moisture like butyl tape.
Short of using metal rivets or screws, I am not sure how one can attach metal screen without some kind of tape. The butyl tape I use is pretty solid stuff. It is used to seal the roofs of RVs.
Heard about the Irish Soap bar thing… turns out rodents love it! Was it a prank all along?!? ?I think I may have told this story before on here, but my wife told me she saw where Irish Spring bar soap deters rodents. So I took an entire bar of it and cut it into slivers and put them all over my shed where I store my Harley. A couple of days later I found that rodents said FU by gathering said soap slivers and put them all over my Harley's engine. F*****k! Took me days to get all that soap off the bike.
Luckily, a black snake moved in not long after that and demolished the rodents, so much so he moved on a while later.
I’ve also utilized some essential oil type repellent with no joyI use all kinds of spray - peppermint oil, cinnamon oil, and cayenne extract. I buy the sprays and then fortify them with pure extracts. They still like to nibble on my battery blanket.
They chewed through my battery tender wiring but no other wires yet. I also place those rodent-repellent pouches all over in the truck and the engine bay.
And, mostly in the summer, I leave to hood open on nice days and then frequently use an air gun to blow around the engine bay and under the engine cover. I've had acorn shells around my battery. =(
I don't think the sonic things work, not from all the reading I've done about them.
Not sure these sprays do much, but Soupie sure smells minty fresh when I go for a drive! =)
That looks promising. I’d verify the temperature threshold of that adhesive though, engine bay gets hot and after several temperature cycles it may begin to peel… just a thought.I‘m well familiar with butyl tape. I used many rolls of it to attach vapor barrier to the concrete walls of my crawl space when I enclosed it. Great stuff, but no contest for a mouse.
Maybe something like this butyl tape with metal mesh built into it. I don’t know how hard it may be to work with.
https://www.wildlifecontrolsupplies.com/animal/WRAT00X.html
I also live in a squirrel dense area, who is probably the culprit in my situation. I sympathize with your story. Need to start breakin out the Ruger 10/22
I tried that with ground hogs taking residence in my backyard...made their hole smells better...in the end, constant .22lr harassments and filling rocks in their hole eventually persuaded them to leave little Chicago...Heard about the Irish Soap bar thing… turns out rodents love it! Was it a prank all along?!? ?
When I was a kid, cutting an Irish Spring bar up with a knife got me in trouble.I think I may have told this story before on here, but my wife told me she saw where Irish Spring bar soap deters rodents. So I took an entire bar of it and cut it into slivers and put them all over my shed where I store my Harley. A couple of days later I found that rodents said FU by gathering said soap slivers and put them all over my Harley's engine. F*****k! Took me days to get all that soap off the bike.
I can relate getting into trouble...When I was a kid, cutting an Irish Spring bar up with a knife got me in trouble.
I was probably 5 or 6, in the old commercial the Irish speaking accent gentleman used a knife and cuts a sliver off the bar of soap.
Well a curious 5 year old and a knife , while taking a bath - imitates the commercial and plugs up the bathtub drain with the slivers.
Childhood Memories
Could be!Heard about the Irish Soap bar thing… turns out rodents love it! Was it a prank all along?!? ?
Wonder what the process is to collect and bottle coyote urine?anyone tried using coyote piss?
Here you go.Wonder what the process is to collect and bottle coyote urine?
