KingsPoint75
- Thread starter
- #1
I posted on "First Long Trip" a year or more ago asking about a seat extension for long legged folks. No response, but 393stroker asked if I had heard anything. Since I didn't hear anything, this past Fall after Deer season, I built an extension frame and moved my seat back 3".
I didn't keep my notes but I remember how I did it and have created a PowerPoint and a PDF (same content) that describes the process. I haven't had access to drafting software for 40 years but PPT allowed me to lay out an understandable document. I added a couple of pictures of the installed steel frame with the diagrams. (It doesn't allow PPT so I only uploaded the PDF. It should be the same)
IT isn't an easy project if you don't have the tools. It's a pain in the ass if you do since the space is tight. You can bolt everything up but I don't recommend that, if a bolt comes loose, you'll not be happy at speed. You should weld the outside "U" (I_I) and can bolt the inside cross member.
Make templates out of wood and test fit every time you make a new piece.
Good Luck!
KingsPoint75
Good Luck!
KingsPoint75
