Colo_Ranger
it helps a lot and was about the cost I expected. It’s hard because the new FDU from BroncBuster is 8k. Not sure if the full FDU is worth the extra 2 grand but it’s hard to ignore when you’re already spending that much. And the tube mount is reversible on their version. It wouldn’t be nearly as bad if we didn’t need new axles to make it work. I wonder how hard the oe bronco axles would be to modify to fit. Maybe cut off splines on the outer side. I’m just thinking out loud here.Thanks for the complement, it certainly has a cool factor.
For the parts list I listed, at the time I paid roughly around $3k, including the rear diff cover. The custom axle shafts I had ordered through Branik, was roughly $1k. For the fabrication/ install of the axles and M210 by Shaffer's $2800 or so. All the parts aside from the custom axle shafts, I ordered through Steeda at the time. They had the best pricing that was available online.
So roughly $6k all in all. The upgrade may not make sense for everyone, certainly did in my situation with the busted/bent FDU mounts. For OEM width Rangers, I would assume that the OEM Bronco CVs would need to be shortened by an inch or so.
I'm not a fabricator or mechanic, but my inference from talking with Shaffer's team, mounting the M210 wasn't too big of a challenge. The biggest challenge during the process (in my opinion) was the long wait times for parts.
Hope this helps!
