Newly Installed 265/70/17 Kumho Roadventure A52: Rubbing to Crashbar
JimmyH
Jimmy
TX
2023 Ford Ranger XLT Crewcab; 2020 Ford Escape SEL
I know this an older post and I'm not sure if OP figured out a solution or gave up and went with a different tire, but while looking into these same tires, I came across an interesting finding. Revs per mile for a P265/70r17 are usually somewhere right around 657. TIRERACK lists the revs per mile on the Kumho Road Venture AT52 in size P265/70r17 at 636. If that is the case, then this tire is 3.3% larger in diameter than a true to size P265/70R17, which would be the equivalent of a size or two larger. I've also found these specs to indicate a larger tire than true to size in various sizes of the Kumho Road Venture AT52. Can anyone else confirm if their AT52s seemed large or true to size?
2021Ranger
Barry
NJ
2021 Ranger
That there is interesting same listed tire size but different diameter..
So I have 18“ wheels on my 21 FX4, it was said that the wheels are a different width and offset Than the 17” wheels?
