armoredpig
Hi, it's tapped to one of the unused fuses under the hood. It's only on when the ignition is on. I did this because the bulk of the wiring harness is up under the hood and that was the closest place to tap. If you look at my underhood pic, you can see a little red wiring entering the side of the fuse boxhey i went with the exact setup as you but Im stuck with the tap a fuse wire and where/what fuse to tap into. I can see in the pic that its running into the fuse box. Do you have constant power to it or only when the ignition is on? thanks!
