Fitzmotor
Gold Sponsor
Ha, you should try keeping track of the listOh...ok. it's hard to keep track of your own posts.
Make sure that you're fully up to temp before taking measurement...otherwise, you may be mislead into overfilling...drive at least 1 hour at highway speeds or have an OBD reader that can tap transmission temp...don't take it out for 10 minutes and go by that reading...
Temp is temp, no matter the time of year....195 degrees is the same 195 summer or winter....just may take a bit more time during winter.Is this the same during winter months? Or is it best to check during the summer?
That's what I thought. Thanks for clarifying.Temp is temp, no matter the time of year....195 degrees is the same 195 summer or winter....just may take a bit more time during winter.
I have temp readout from trans and it's tough to get it to 200F sometimes...driving at casual speeds (40-60mph) for 2 hours, the temp didn't get past 190F...ambient temp was around 60F...at highway speeds of 70+ over an hour, the temp will easily get to 200F...probably not much difference in level reading between 190F and 200F...That's what I thought. Thanks for clarifying.
Someone else posted an alternate way to increase the temps, which I found to work. Lock out all the higher gears so you are running at 4k RPMs - the trans temp will rise above 195 reasonably quickly - but it is still pretty amazing how long it takes.I have temp readout from trans and it's tough to get it to 200F sometimes...driving at casual speeds (40-60mph) for 2 hours, the temp didn't get past 190F...ambient temp was around 60F...at highway speeds of 70+ over an hour, the temp will easily get to 200F...probably not much difference in level reading between 190F and 200F...
I wish I had laser etched vs electro etched from the beginning, but getting that done after it was already made was tough, it was easy when the mfg does it for you.Heh, Mike, I have one of the first batch, #7 I believe. How can I get one of the improved engraving new sticks. Maybe I missed it. Love the Fitzstick, but any improvements to help these old eyes see the level better would be appreciated.
Not a problem on the shipping. Would not expect less. Just PM me with the details on the to/from location on the measurement and what the cost will be and how handle it.I wish I had laser etched vs electro etched from the beginning, but getting that done after it was already made was tough, it was easy when the mfg does it for you.
Ah yes, #7 one of the first.
I did not start recording the lengths until later, I will have you measure it, then I will set the length on the new one and ship it out.
I ordered 100 of them to cover all the previously sold ones and spares if I get some bad ones in the batch of 300, should be a couple of weeks, then I will ship them out, just cover the shipping if you would please.
Thanks again
Well, like I say, it's almost like Christmas. Eve at my house waiting for the u p s man to show up with my new mike stick tomorrow.There is also one huge difference, at least between the B&M and Mike's Fitzstick (aside from the obvious measuring dipstick and its markings, and being a blade rather than a piece of wire)...
Mike's stick tube is preformed with the right bends to litterly drop into place on the nut fitting you screw into the trans case.
The B&M is just a straight piece of tube which has to be curved by the installer, while trying to screw the two fittings together.
Having installed the B&M prior to Mike's, I can tell you it is a night and day difference....the B&M almost requires 3 arms/hands to install.
Don't know, but it appears ST's stick tube might be similar to the B&M. Not saying that's bad, but the slight and very subtle bends and curves formed in Mike's tube make it a very simple install.
I don't think you are going to regret the purchase. I certainly don't. I own both the MBS and B&M sticks. Mike's wins hands down.Well, like I say, it's almost like Christmas. Eve at my house waiting for the u p s man to show up with my new mike stick tomorrow.
