Tree Ranger
- First Name
- Mike
- Joined
- Feb 14, 2024
- Threads
- 1
- Messages
- 4
- Reaction score
- 0
- Location
- California
- Vehicle(s)
- 2019 Ford Ranger
- Occupation
- Forester
- Thread starter
- #1
I have a 2019 Ford Ranger with approximately 51k miles on it. Around four months ago I heard intermittent water sloshing noises under the dashboard when having the AC on. Defrost setting, air blowing up, thermostat temperature set to half. A couple of weeks later in winter I also noticed it when only used in heater mode, no AC, same temperature setting defrost mode only. The noise is now constant when the engine is fully warmed up; it sounds like sloshing water and/or air bubbles.
Coolant levels are normal, no loss of coolant, no water in the oil. Since I have the truck I never saw any water puddles underneath the truck, even in the hot summers here in CA so my first thought was it might be a plugged AC drain. Four months ago I turned the truck into the Ford dealership and they said they could not verify anything noise never stopped.
Three weeks ago I got a deeper aluminum transmission pan installed on the truck and the mechanics shop stuck an air hose in the AC drain which is underneath the transmission and water came out but no improvement at all; noise was right back when I drove it home from the shop.
Since the noise is now almost constant, especially when truck is idling or in front of a traffic light, I again turned in the truck to the FORD Dealership since I have the extended Portfolio warranty, and they burped/purged the radiator and stuck an airhose in the AC drain as well. The noise is still there, not as loud anymore but still there; I still hear sloshing. There are still no water puddles underneath the truck; not sure if everything evaporates on the hot transmission. The noise only occurs in the defrost mode.
I also learned that the Ranger does not have a radiator cap anymore since I tried to purge it myself. I left the coolant cap off and parked it in uphill & downhill and level position and let it run each time for 20minutes after engine was hot with heater on high temperature setting. Not sure how the shop purged it or if there are any purge valves/screws.
The truck does not slosh when shaking the cab the Technician tried that as well.
I saw two posts in regards to this issue on this forum from a couple of years ago on this issue but there was no answer how it was resolved.
The constant noise is really annoying and I am ready to sell the Ranger because of that although it is the best truck I ever had and I really like it.
Should I replace the coolant level cap?
Any feedback how I could get rid of the noise or what the dealer can do in order to get that resolved would be greatly appreciated.
